Michele Branch
Elwood
I just saw an add for some Christmas Special on NBC this Wednesday night at 8 p.m.
It listed Michele Branch as one of the musical guests, I just thought I would mention this since I know some of the guys on here are big fans.
Ha.  Michelle does tend to get a lot of attention around here.  Perhaps it's her pouty lips, or her sultry voice especially in the new Santana tune...hmm, I'm sure others have some thoughts.
shutup jeremy  :jester:
Yep  not gonna miss that one it's the Lighting of the Christmas Tree special, theres gonna be alot of good singers there this year.
    • The filtering to wear relationship goes like this:      'Relative Engine Life "Factor" new divided by the factor old. So 8/3= 2.67. That result is the multiplier thus if a motor had an effective life of 100K using a filter with a 45 micron rating at a Beta ratio of 75 then a filter with a micron rating of 10 at a Beta of 75 would improve expected engine life to 267,000 miles.    Wear metals are an indirect indicator. Less is better and the motor lives longer but there isn't a multiplier like there is for filtration so well documented. Most of that has to do with the sensitivity of the wear metals tests themselves. The read a 'slice' of the spectrum but not the absolute values for the entire spectrum. So a general indicator that is used WITH the results of other tests. Two others considered in this post.    There is also the influence of corrosive wear which may be seen in the wear metals but separate from load based or viscosity mitigated indication. It's a small graph but the gray line is wear vs the TBN/TAN crossover. Not as useful as it used to be as there are now new chemistries for acid remediation that don't show up in standard UAO testing. They will catch up or be found liars. Only two possible outcomes, eh?
    • One thing that comes up over and over is that the torque converters are the weak link. Many of the failed transmissions have the same thing in common. The torque converter grenades and then metal torque converter shards end up destroying the transmission. One of the best things you can do is if your transmission is still fully functional, change out to one of the aftermarket billet torque converters. There are several good choices mentioned in different threads here to make your choice. After that, then you can decide about trans tuning. My trans failed at around 95,000 miles. It got replaced under the GM protection plan. The remanufactured trans comes with a 100,000 mile /3 year warranty. I still have just under 1 year left. So far, so good. As long as it's still working good next year, an aftermarket torque converter is going to get installed early spring. If the trans and OEM torque converter fail by then, I will get it replaced under warranty and immediately have an aftermarket torque converter installed. A warranty replacement trans of a replacement trans will no longer have the warranty so I will bulletproof it from the get go.
    • You got'a be cooking right now. Just looked at the weather map. Yuck!    We are right back to $4 today.
    • Pushing $4.00 a gallon in most places, still $3.75 in town but it's going to spike tomorrow for sure.   Diesel back up to $4.60-5.00.
    • I really appreciate the response.  I guess I was confused about torque angle vs torque angle yield.  The individual bolts don't have a warning on reuse but the part number for the LCA nuts does.   Regarding the purpose of the moog grease fittings on their bolts .. Guessing to reduce possibility of corrosion locking the cams or seizing to the bushing inserts.
