What Size Brakes On The Rear?
Let's hope those work.
I suppose I'm lucky living in SoCal...little or no rust.This might be a stretch but as a last resort what about cutting the bolt heads off with a die grinder just to get the hub off,then get a replacement at wrecking yard :lol: like I said,a stretch.
That was my first idea, problem is the bolts are set in slightly so i'd probably damage the knuckle doing that :lol: . I am not worried about damaging the hub since I have the new one already, and bolts I can just get anyway as well. Gotta see what I can scare up this week.
The rust is insane here, if you saw the underside of this truck you would be :dunno:
  • Replies 64
Have a good welder weld you some nuts onto the exisiting bolt heads before you attempt to remove them. That or it's hub AND knuckle time.
The sockets I hope to use look like this:
They usually work pretty well... If I had to go with the whole knuckle that would hugely suck, because then I would need to replace the rotors as well.
I have a set of those sockets and while they work extremely well, I'm not so sure that they will get a bolt of this size and torque out. Haven't had to go that far in my set yet.
My friend has a set thats hardened (black) like air sockets. I'm gonna use those because I can say with certainty a regular one would probably shatter.
Again, same here and they work extremely well in the applications that I have used them in. Again, just nothing of that size have I had the grand splendor of dealing with yet. Pound the smallest one on that you can fit and use smooth, even pressure on the breaker bar while praying to the good lord and you just might get them. I wish you the best of luck. :lol:
LOL thanks, I'm gonna need to pray all week just to make sure I have enough saved up for this one!
Any progress? :lol:
Thanks for asking, none this weekend. Girlfriend dragged me out on Saturday, and we did some development work on the race car's new suspension Sunday. It works great, except we managed to blow the headgasket by the end of the test!
Possibly working on it this upcoming weekend, or definitely next.
Small update, changed out the radiator this weekend, and also changed the oil which seems to have cured the oil pressure problem. Turns out the last time the oil had been changed was somewhere around Nov/Dec of 2010 and the truck was likely not driven much at all since then so we figrued maybe the oil broke down a bit. We put in 5 qts of 10w40 and a can of STP oil treatment to be safe and the pressure is dead on according to the book.
Still no pics yet sorry, but will be working on the hub/gas tank at the end of this week/beginning of next, will get some then.
Rusty pics for your enjoyment... mint shock mount on there as well:
https://picasaweb.go...feat=directlink
Wow,that's some serious rust.I'd guess it would be next to impossible to get rid of it.Glad you got the oil pressure problem solved :thumbs:
Bad news on the oil pressure, it seems to be back. Next I'm gonna change the sender... after that if need be the oil pump.... after that... the engine :(
As for the rust, I'm gonna wire brush it all and rust treat the hell out of it. The truck definitely has quite a few working years left. However as you can see the rear passenger shock mount is SHOT. Got both side on order from Rockauto right now, will be installing Tuesday....
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
