Brought truck in for surging
Well I finally brought my truck in for the truck surging ahead at different times when coming to a stop, and they told me this is normal and its the computer not reacting fast enough to stop before surging ahead for a brief moments. I told them this not normal and very dangerous, especially now that winter is coming and was told they all do this, its normal. How long can you argue with someone!
Going down a rough road the truck creeks like crazy, TSB out on this, well just got it rustchecked undercoated before it was brought in ( factory undercoating came off surface rust on all parts that was off, they said oh sorry we can't do anything for that) and then they said can't doing anything with it because of this. What a crock, this is snowbelt country with salt, on the roads. I just got so frustrated, I will fix the problem myself. You spend big dollars and this is what you get in return, I'm pretty ticked right now o say the least.
This is one reason I prefer manual transmissions. With a manual transmission, I am in control of the vehicle at all times, and no stupid computer will decide for me when and how to shift. A problematic auto transmission can be a lot more frustrating than a well functioning manual one.
As for lousy warranty service you are getting, I would try another dealer. I agree with you that GM truck chassis protection is inadequate. If I compare my truck to my 1985 Mercedes 300D, I must laugh. The entire chassis of the Mercedes, including brake lines have been encapsulated at the factory with some kind of sealant, several milimeters thick, similar to spray in bedliner. I do not expect GM to do something like this, but come on, leaving the rear wheel wells bare without a standard liner?
Ok if you want an answer, as long as it takes. Take it to another dealer. Call the next level of support from GM. Start sending letters, make a case for the lemon law, they cannot ignor that. If they ignor it, they will get the truck back.
God I hate customer no service.
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
