extra wires near fuse box...
I found the 'hot wire' for the 7 pin trailer plug, I thnk. It was under the brake booster. I have another wire between the fuse box under the hood and the drivers fender. Does anyone know what that wire is???
Thanks Hud
This wire is for accesories power to the back trailer plug. Also to get power to the wire once connected to the left post on the front of the underhood fuse box you must insert a 40amp fuse in the blank fuse area in the under hood fuse box. It is kind of wierd how you must cross the wires to the fuse box connectors. The wire from under the brake booster connects to the right post. I also put loom on my wires to make them match the rest of the harness.
okay... wire from under the booster is for ________________, and the wire between the fuse box and fender is for _____________.
Please fill in the blanks.
I have the factory trailer brake controller, I certainly figured it would come from the factory ready to run.
Thanks
Hud
there are two posts by your underhood fuse box. the wire will only go on one post so put them on the appropriate post put the fuse in and the plug for the brake controller is under the dash. its just plug n play just buy a brake box.
Larry O , you are telling me that I need to buy a 'brake box' to go along with the factory integrated brake controller that I mentioned in post #3? What is that exactly and where do I get one?
Thanks
If you have the factory brake controller that wire stays disconnected. And you don't need anything else to tow other than the trailer. ;)
that is what I thought. I appreciate it Mike.
Hud
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
    • It’s at the point of amusement. I’m retired I have time. It’s fun seeing people try to convince me I’m using oil. I’m buying oil at the prescribed time. It gets drained and new goes in. Do I add in between, no. My oil doesn’t even get dirty in 5k miles. I don’t even see any drop on the stick. I check in the same place. All is well.
