5.3 connecting rod #5 breaks
Well here's my story I bought this truck new it has 88000 mi. and #5 connecting rod broke , I'm like WHAT ! Truck was not abused ever , and this happen on a start up in warm temp. with a 500 mi amsoil oil change on it . I'm told connecting rod could have been broken for a while and then all the stars linged up and discenagrated this motor. Why would a connecting rod break,? has this happen to any of you and did GM stand behind you ? if so how old was your truck and what was the mileage. I'm told these motors are good for 300 000 miles so why me . were there any recalls out there I missed . Anybody know anything about Auto I web they have remanufactured engines for like $2360 by the way it's a 2001
Very rare is all I'm going to say. I've been on these boards since 2001 and quite frankly the only ones I read of having issue were guys who ran to much boost. :dunno:
I think he saying he bought it new and it now has 88k on it.
You're right. Misread... my bad.
I bought this truck new. No boost stock back to front top to bottom. I'm 61 yrs. of age truck has never been beat or taken off road , has only seen dirt roads 3,4 times . @ 18000 miles the truck developed what GM calls lifter noise / piston slap, was told they all do that it's normal. I said "not" nomal but that was my answer, I'm the only driver of this truck. Has anyone ever heard of a connecting rod breaking @ start up on a 55 degree day That's when it let loose hit the key "TOAST" , Why would this happen, do ya think GM will step up to the plate on a truck this old ?
Piston slap/cold start knock IS normal for these engines. You can try to deny it all you want but that does not change the facts :) Piston slap had nothing to do with the rod breaking otherwise there would be a ton more people on here complaining of the same problem. It's just one of those unfortunate things where you'll likely never know why. Could be a number of things. Truth is any type of mechanical device is subject to failure at anytime. There are not guarantees. Sorry bro, I'd be pissed as well but it is what it is.
So there is still piston slap in the newer 5.3 vortec as well? why don't they do it from day one, mine started at 18,000 miles, I know a guy with a 2006 his didn't start till 60,000 miles. I do appreiciate the feed back as well as the symapathy. Will a remanufactured engine have piston slap? Can anyone tell me what causes it?
11 year-old vehicle....... not much chance.
I'm wondering if you may have lost a head gasket and water seeped into that cylinder over night. Water doesn't compress very well and the piston hitting it could break a rod especially if other cylinders fired before this one came up on compression stroke.
My guess is, when/if they pull the heads off, they may find water in that cylinder.
My dad one time had a cam shaft let go on an S10 Blazer. It was just over 5 years old and had 60,000 miles on it. GM wouldn't stand entirely behind it but did split the labor cost with him :dunno:
Still rare.
Not that I'm aware. I don't recall any complaints about "piston slap" on the Gen-IV motors. That doesn't mean that none do it (?), but it's not common.
I had read that theory somewhere about head gasket blowing. I had the motor tore down there is no apperant reason , S--- happens, I 'm told! As Rocky Seria said if it's mechanical anything can happen, dosen't mean we have to like it. life goes on and so will this truck as I have a new remanufactured motor from Auto I Web going in it. Up untill this point that truck was problem free, so I say body is like new I aways keep it oiled with new oil a tacing agent and a rust inhibater. and that has payed off. Living in a snow belt ya got to do something to stay ahead of rust.
Did the rod punch a hole in the block, tear up the cylinder wall or do any other major damage?
If there was no water in the cylinder then the rod must have just had a defect in it... That's a shame but sure doesn't rise to the level of replacing the entire engine unless there was a lot more damage.
I feel for ya but you're right..... "life goes on".
yea there was about 41/2 inchs of connecting rod entirely missing ground up in motor . Mechanic says he thinks it was broke fore a while and cause it is a 5.3 and I was not working it , ithe stars all lined up and it imploded. It would be a total tare down and rebuild.
    mark2
    mark2
  • Who's Online   5 Members, 0 Anonymous, 648 Guests (See full list)
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
