Random No Crank on 07 Sierra
flattop
Happy Holidays!
I have a 07 Sierra SLE RCSB 2WD 5.3 that I bought new in August of 2008. Up until two weeks ago, the 85,000 miles I have logged were mostly trouble free. I am now getting a random no crank, about once every 2-3 days. All I have to do is toggle the door locks with the remote and it will crank and start-up fine.
I don't know if this has anything to do with the problem, but just before the no-crank problem, my "service air bag" light and message appeared. The dealer did replace my rusty front bumper at about 75,000 miles (no charge, thanks GM and my local GMC dealer!!). Perhaps the connection on one of the sensors is not good?
Anyone had any similar issues and what was the resolution?
Thanks
Tim
SRS has nothing to do with starting the truck...
cycling the door locks makes no sence at all,the PCM gets a signal from the ign switch and then the PCM supplies the solinoid and vroom goes the engine ,,
take it in ,could be a bunch of things ya know
good luck
Well, If you have an aftermarket CD player installed, the door chime module could be the culprit. I had a cheap chime interface on my stereo and it was cusing all kids of havock with my door locks, starter, and lights on my dash. Ide say that if you have an aftermarket radio, change out the chime interface and see if thats the problem.
I know it sounds strange, but a new interface fixed all of my issues.
Thanks for the reply's. I guess its off to the dealer for a diagnosis on the Air bag light and hopefully there may be another code related to the intermittent no crank problem.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
