Need fuel system design help for 2003 1500 SS 6.0L
mebers
I am putting a 6.0L (LQ9) motor from a 2003 Silverado SS into my 1960 Chevrolet pickup. I bought a fuel tank when I still planned for a carbuereted motor and at the cost of an intank fuel pump I prefer to stay with this tank. The LQ9 has to have a return line. I would like a schematic of how to build the system. line sizes, filter numbers, pump number. what PSI and volume pump do I need? would it be good to have a pre pump to a second tank with a high pressure in tank pump?
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
