5.3L rebuild
I bought my 5.3 longblock with 48k for 500 bucks...they are plenty cheap.
What I would do is find a LQ9...Lord knows you need all the help you can get to get that SUV rolling
  • Replies 44
cheapest I found around here(S.E. Michigan) was 750.+ for a 85,000 motor. after it's all said and done(if the oil passage checks out) I'll have about 1500 into it. minus my time of course. That's total gaskets, pistons, rings, rod,main & cam bearings, lifters, oil pump, and cam. Machining for the block and crank comes to 205.00. Gotta buy 2 new rods due to the mishap with #6 - 85.00. The heads I'm kinda up in the air about right now, weather to rework them or just lap in the valves and check the springs. Backup plan in case the oil passage is cracked - found a rebuild-able short block for 200.00. If I go that route the short block would really only cost me an additional 100.00 because I wouldn't need the 2 rods. Plus, building a motor out in the garage makes the wife think I'm saving us tons of money and keeps me outta her hair :cool:
edit:; of course with lapping the valves, I'd throw in some new valve seals
95% highway, the guy I bought it from used it for the family mobile. I know him and his idea of being rough on was to drive it to the different fairs around here and park it on the grass.
A little background first - 2002 Yukon XL SLT Autoride, 5.3L, 4x4 , loaded with every option available,244,000 miles, #6 rod is broke(assumption- no compression, valve train tight, valves move when cranked, alot of noise when running) bought from a friend that had enough.(spent 4600 since Feb 2011, his wife said get rid of it after getting an estimate of 5800 for a junkyard motor swap) I'm gonna pull the engine and transmission to check it out. I'm pulling the front clip to make things easier to work on and replace any other parts that need it up front. Not looking to do anything elaborate or out of the ordinary , just make it as good or better than stock. Looking for input from the forum about what could be replaced or modified while I'm doing this. Is there any tips or tricks that you have for this type of project? I'm all ears. I done a few, and am always looking for a better way. I don't mind spending money on my projects, but my pockets are not bottomless, some compromises will be made. Will be posting pics of the progress. anyone needing specific pics of anything, ask and if not past that point in the project, you shall receive. Should I move this to another forum? or am I good here?
edit - was a broke rod, decided after talking with the shop that did all his maintenance, to leave the tranny
posted this on another thread, figured I'd put it here , I seem to be getting more interest. Still stands about thoughts and suggestions, I have the entire front clip off and took approx. 200 pics of the process
oil passage didn't hold pressure. shot a stream about 10 ft across shop. had to use magnifying glass to spot hole with the rough texture of the block. so plan "B" it is, already called and will pick up the block in the AM.
well glad you had a Plan B. I look forward to seeing more on this as you progress!
its mind boggling to see a rod snap at 240k on a vehicle that wasen't abused...my old 4.3 had about 400k on the ticker and the only issue aside from being tired was that it leaked and burned oil :dunno:
picked up a "new" 5.3 from the parts yard yesterday. wasn't a short bock , but the whole motor minus the alternator. Had to strip it down, dropping it off this morning.
dropped the block and crank off, it'll be about a week, time to start with the boring stuff - cleaning parts, picked up a helms , 4 volume set for 60.00, waiting on that, maybe I can get the wife to help scrub parts(I'll tell her it's just like scrubbing the floor,she'll probably flip me off) :idiot:
Haha yeah probably! how many miles were on the motor you got and how much did it run ya?
The "new" motor has 139,000, got it for 235.00 out the door. intake was kinda busted up but I was gonna' use mine anyway. Now I've got lots of extra parts.
sweet sounds like a great deal! Did you say the shop is going through it to make sure it's all good?
The machine shop that I am using will check the block,crank and bring them back to factory spec. I'll do the heads and magnaflux the rods and check them for starghtness. The nice thing about the shop that I'm using, it's small and the owner will help with anything I have questions about or are unsure of. example - he showed me how to check my vales for straightness using my drill press and a dial indicator. This guy will get all my future business and any I can send his way.
edit- there's a little more to doing the heads , just using that example to show his willingness to help me do things easier and myself (he checks valves for straightness by putting them in a lathe and spinning them up),
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
