dual zone climate control
rc51matt
the air worked just fine this summer but the heat only blows hot air when it's set to 90 and then itll cook ya. at 89 it blows cool air in. also when i use the remote start it never blows warm air just cold at full blast. at least the motors warm. i changed out the antifrezze and flushed it in the process with no differant results
Do a search for blender door actuators. It would seem that a few people have that problem. Your air flow is not being directed across the heater core properly. Good luck & happy reading!
Dosnt seem to be my problem. air will come out wherever i want it. but itll only be warm when its at 90
Not saying the blender door actuator is the problem, but if that is your problem it doesn't restrict airflow... Only the temp of the airflow. My wifes Yukon Denali (gmt800) has done it 2x since we bought it. Airflow is fine but it would only blow hot. Both times I pulled over, shut if off and then restarted the motor and it was fine.
ok that makes more sense. its been doing it since it got cold. at least i can have it at 90. rather be too hot than too cold
You may try and reset the system. My GM800 required this after I had it apart for a lengthy repair. Set your temp control all the way to the cold setting and your vent control to the vent/dash setting. Disconnect the negative lead on the battery and let it sit for a couple of minutes. Reconnect the battery turn the key to the on position, do not start. Let it sit in the on position for a good couple of minutes. Turn the key back to off then start the truck.
I had to do the procedure twice, once to get the proper vent control and then to get the proper temp. Good luck.
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
