Opinions please, just got my new wheels and tires on.
BlkSilverado2011
okay so for those who are interested in the mirrors this is where I got mine and it shows they have 5 left instock. $148 with free shipping power and heated mirrors. http://www.ebay.com/itm/130574049258?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I love mine wife took the truck today is very happy with them.
It looks sooooo much better. Keep it up.
Thank you man, this weekend I am going to wash it and try and paint the front and rear bumper, grille and steps. I might just plasti dip for the time. I messed with that stuff on my wifes mustang and actually is really cool.
Looks good and liking the mirrors. Did your stock mirrors have power fold in / out ?
Thank you, I didn't have the power folding on mine, wish I did.
  • 1 month later...
Looks great, love black rims. Enjoy them!
Thank you
Those look good. Specs on lift? Also, lose the chrome steps/ door handles. They don't really go with the theme of your truck.
lol thank you, I know I will remove the handles tomorrow, but might get some plasti dip and do the steps.
Sorry I got 1 inch bodylift and 3 inch level on the front and additional 1 inch on the back.
I like yours Blackout.
you have a 3" level on the front????
I do like the way yours sits and I would like to have a more dramatic lift versus just a 2" level....but I've heard nothing but bad things about anything more than 2.5" in the front....
Nice rims, however they are not a 0 offset, a 0 offset would place the hub of the rim directly in the middle, with a large outer lip. If your rims are "hub centric" and do not have added thickness to the hub, you are looking at a positive offset of about 25mm, and if this is the case, they are probably a one piece cast or forged rim.
JMHO
JMHO
Straight from Raceline:
Part #. Size. Bolt Pattern Offset. Backspace
901-29066-00 20x9. 6x135mm/6x5.5 0mm 5.00
Awesome ! looks great !
Next truck I get I'm going all black but its gonna be a while..put too much into mine already (just replaced the tires also)
if you put a set of the tail lights i have on my truck that would look sick...
great job!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
