ABS brakes
666amf
on a 2008 gmc sierra 1500 z71, i replaced caliper, wheel hub, brake line, bleed the ft. brake only, went to Auto zone to clear codes no luck as their scaner will not clear abs and parking brake codes, where are the fuses located for the ABS and parking brake, or must i have to go to the GMC dealer to have codes cleared?
check owners manual for fuse location ,or underhood fuse block cover for fuse location ,
ps ,was the ABS light on before the repairs ?
PSS,the parking brake symbol is on when the ABS light is on,
the ABS light came on when the wheel bearing let go, as a fire started as the grease catches fire, burned wires, cv boot, etc
Burned wires? You replace them wires? I know how finicky these issues can be so the right amout of wire used is best. You don't want more resistance then required. So check all wiring to make sure.
