Tranny problems
I had a front end collision, wrecking my rad, condenser, rad frame, tranny cooler, and headlights. Now that I've fixed the problem I'm having transmission issues. Forward gears work great, but reverse doesn't, and neutral is a forward gear too. What do I do? What issue am I looking at?
Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. May also have worn boost valve (can replace in the pan).
Because of the trans is still in gear when the shifter is in the neutral position I thought it could be just a problem with the alignment.
so long
j-ten-ner
you take the truck to a garage and have them diagnose the entire complaint and they provide an estimate ,they may want to take it out and apart also (( i would )) ,,
never ask what an internal problem will cost on the internet ,
never tell a shop what YOU think is wrong ,when it goes wrong ,its your butt ,not the shops
good luck
