Service trailer brake system come on my Vehicle Information Center an im not sure why, I accidentally grounded a hot wire under the dash when i was hooking up my work lights on my rack. I have checked the fuse under the hood and disconnected the battery for 15 minutes an it still comes on. If you squeeze the blades the input comes up on the dash its on a 2011 Sierra 1500 with integrated TBCS. Id rather not deal with the hassle of going to the dealer and having them fix it but i will if i have to Thanks
stab in the dark here:
check ALL fuses related to not only the electronic trailer brake system but also those for the trailer - there are several under the hood in the fuse panel. Sounds like something is shorted out, if you grounded a wire that was hot then you either blew a fuse or screwed something up in the computer.
  • 5 weeks later...
Hope you will not have any more issues. We have a 2008 GMC 3500 with IBC. We have had nothing but problems with this integrated brake controller. We have had failure 3 times, the DIC will show "Service Trailer Brakes" when there is an issue, when you have this warning, YOU WILL NOT have power to the Trailer Brakes. The first time this happened, we had to drive home without Trailer Brakes, happened while in route, not safe!! We have had this to the dealership for this, they did fix it ( replaced the relay) and told us this was common. We now have had this warning again on the DIC and again we have no Trailer Brakes. Truck is no longer under warranty!!! We are going to install an aftermarket P3, waiting for it to arrive.
Just about to say that. Mine did that to me in the first 6 months I had the truck.
  • 3 years later...
Have the same issue with our 2008 3500 HD POS. Nothing but problems with this truck and it does not have 12,000 miles on it yet. Can anyone tell me where the relay is that was the problem? Anyway to test it?
  • 2 years later...
  • 5 years later...
L'utilisation des applications mobiles fournies par 1xBet Casino est un processus simple et efficace. Pour commencer, il vous suffit de télécharger l'application mobile gratuite depuis l'App Store ou Google Play sur l'appareil que vous souhaitez utiliser. Peu importe le nombre de fois que vous visitez le casino 1xBet https://1xbetcasino.fr/ vous pouvez être certain que vous y vivrez toujours une expérience merveilleuse. De plus, le personnel du service client est là pour vous aider si jamais vous rencontrez des problèmes ou avez des questions sur le programme ou les services qu'il offre. Depuis le confort de votre appareil mobile, vous pouvez profiter de toute l'expérience du casino 1xBet sans frais supplémentaires, et vous pouvez jouer à vos jeux préférés quand et où vous le souhaitez.
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   2 Members, 0 Anonymous, 564 Guests (See full list)
