bilstein 7'' lift struts???
hey guys i was thinkin instead of stacking a 1'' leveling kit on my 2011 silverado BDS 6'' lift kit can i install bilsteins 7'' lift struts replacing BDS 6'' lift struts? it would be more expencive but i think it would be the right way to do it.
note: the 1'' leveling kit would be a top mount.
i dont really want to stretch the BDS kit at all but right now my tires rub when i go over bumps lol
thanks!
  • Replies 36
The term "strut" is applicable and is what they're stocked/sold under. Albeit not the original definition of a "strut", if that's what bilstein /Monroe/Rancho/etc list them as in their catalogues, there's no reason to nitpick here.
I called Cognito who sells the struts and this is the Email chain.
"Jake, unfortunately, these will only work on a lift that is exactly 7” like ours, this is because these shocks control the droop and bump travel of the suspension. Using this shock with your kit would cause it to have too much droop and it would not limit the up travel in the correct spot."
"Chad,
Thanks for emailing me back. Im just curious tho, what is the difference between my setup now with a 1'' leveling kit and your 7'' struts? are you saying it will not fit? too much up travel is better than too much down travel correct?? the truck is mostly used on blacktop. I take it offroad now and again but just for hunting trips and the occasional back road cruz."
"The 1” spacer helps limit the wheel travel. Vs. Our shock allows for all up travel and even more down travel. Too much up travel means shearing off balljoints on the a-arm, maxing out tierods until they snap, etc… Too much down travel equals all the same plus binding of CV axles, etc…"
Whats your opinion on this? I believe in what this guy tells me but for a truck that spends most of its life on the street i cant see it being too big of a deal. the question is when i do take it out whats the chance of something serious actually happening?
the down travel is restricted by the factory "bump stop" welded under the UCA but as far as over extending the suspension UP i would have to think it would take a pretty hard hit.
comments.....??
it isnt applicable and it isnt nit picking, people calling them a strut just shows they don't know suspension systems and just because it is stocked under that doesn't make it a strut, it is a coil over shock
People call them a strut because that's the term they're sold under from every manufacturer. Your post proves nothing except that you like instigating arguments by degrading members who refer to them by the term "strut" as "not knowing anything". Lol with that attitude I hope you enjoy your short stay. :)
"Unfortunatley I don’t have that measurement on hand. I don’t know what it would be with the stock spring in place. I don’t have one to test."
this is my opinion. as far as up travel it cant be any higher than that of the stock spring will allow correct? even with the BDS kit all it was was a "longer" strut, the distance from the top of the assembly to the bottom of the coil-over is the same as it would be from factory and with the Bilstein struts this would be no different.
as far as the down travel it cant be any further than the factory bump stop that is still remaining. granted the factory setup would not allow it to reach this point because of its factory strut length but nevertheless it is there.
so in the end you will not be able to min/max this new bilstein shock to its extreme but you will affectivly lift your setup an additional 1'' due to its longer bottom shaft. so if your tearin up some dirt and you hear a loud CLUNK! that will be your factory min and max stops bottomming out. "even tho your strut can do more"
am i wrong?
I think you'll be good with it. In the end the fully extended length probably isn't much different than your current setup with the spacer (general 1" longer of a body does not drastically change the travel range)
I dont want to get off topic or pick a fight but here is a few steps from the BDS lift install manual
48. Locate the two captive nuts on the OE strut bar pin. Carefully remove these nuts and transfer them to the new strut.
49. Install the new strut assembly to the appropriate frame mount with the original nuts. Torque the nuts to 40 ft-lbs.
Note: Be sure that the strut is oriented properly in the vehicle.
50. Swing the lower control arm up to the strut and fasten it with the original mounting bolts. Torque bolts to 40 ft-lbs."
They call it a strut as well.
Why would I possible be banned because people do not know the difference and I am trying to correct them?
Since everyone is googling someone go and google and see what the gm specs say for type of front suspension, if it says strut I will admit I am wrong, if it says coil over spring then you admit you are wrong.
Lol actually I'm more amused at your lack of reading compression. ... I guess everyone should email BDS and complain that they call them the wrong thing so members stop looking like idiots in front of suspension goddesses like yourself.
Ill go correct everyone on my Jeep forums too. ;)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
