factory back up camera, with gmx550
I have a question on factory backup camera.
The camera works great ...put it in reserve and on it comes , I have the factory nave unit. I added a gmx550 to the truck to allowing using the screen to watch movies thru the I pod or a DVD player, It all works great .. This gmx550 also allows you to turn on the back up camera even if it isn't in reverse, but you have to connect a wire from the gmx 550 to the camera...OK here is the question. Does anyone know which wire the camera using to turn on the camera when it is put in reverse, this is the wire needed to connect to the gmx550 there are 5 wires coming out of the camera where it is mounted in the tail gate.. Just don't which one is which, I also think this wire connection can be made to the mbec under the dash
Thanks Jim
Thanks Jim
If this is a NBS pickup, the reverse camera power lead is the dk. blue in the upper right pin (pin 8) of the upper right port in the left I/P junction block:
Cut that wire and hook your camera output wire from the GMX-550 (orange/black, I believe) to the HARNESS side and cap off the stub of the wire that's coming from the plug.
Hello Walt, Followed the above instructions, Camera still works in reverse, while in forward gear and you active the rear camera via the on -off of the gmx550 the screens goes black , no picture, turn it off on the gmx550 and goes comes back to whatever was on before, say nave screen, It also does come on in park using the on off of the gmx, just not when it is in forward, I wired to the harness cable side , not the plug side , is it possible this may need to be reversed?
Walt..... I did check the voltage at the connector.... 12 v, Actually the system does work , but the camera only stays on for around 10 seconds then goes the screen goes blank, so start the vechile put it in reverse, camera comes on and stays on... shift to to drive, turn on the gmx550 and go to rear camera but , stwich it to on... Camera comes on , but only for around 10 secs. Not sure where to go from here. Any Help?
well any one who is interested , I finally found the reverse wire for backup camera, everyone was saying it was the blue wire in the x10 connector of the MBEC, which is wrong ..that wire is for the backup lights... keep in mind this truck is a 2009 silverado with factory nave and back up camera....The wire that controls the 12 volts to the camera is a lt green wire in the BCM module located just to the left of the MBEC module. If any one is interested I can post pics of it.. Everything works fine now , I can shift to reverse and the camera comes on , then put it in drive and turn on the camera rolling down the road with the GMX 550, Ive been working on this for 4 weeks now glad to have it working
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
