Going to 20" wheels from 18"
tpdolph
was wondering if I needed to have my speed-o corrected when changing to the 20" wheels, seems likely I would, can the dealer do this?
The size of the wheel doesn't matter. The overall diameter of the tire does in regards to the speedo. What size tire are you planning on running? My truck didn't come with 20"s but I put oem 20"s with the oem size of 275/50/20 which has virtually the same outside tire diameter of the stock setup.
So my speedo wasn't affected.
Thanks SouthCo, Actually the wheels you have are the ones i'm wanting to purchase (nice set-up you have) My current wheels are P265/65R18 and the ones I'm wanting are your size P275/55R20, So i should be good to go? Also Did you get the TPMS installed before or after you purchased your wheels, the reason i'm asking is, don't they have to take the tire off to install them? Thanks
All tire manufactures actual sizes can vary somewhat. So a goodyear p265/65/18 tire may have a larger or smaller diameter than a bridgestone p265/65/18 tire. With that being said, you should be fine. The difference in diameter should be less than an inch.
I got my 20" wheels/tires off ebay and the were new takeoffs. They already had the TPMS in them and were ready to bolt on to the truck. So I just had to program them to the truck. If you add the tpms after the fact, yes the have to break the bead on at least one side to get the TPMS installed.
  • 3 weeks later...
    overspeed
    overspeed
  • Who's Online   4 Members, 0 Anonymous, 382 Guests (See full list)
