Gm valve cover Qustion
heya i think i have a smiple question this time, i was wondering if anyone knew if they make blank valve covers for the 350. i looked threw the summit site and cant find anything i like. the reason im asking this is because im currently doing a engine swap in my 64' IH scout 80 and i would like to add the "IH" feel to the new engine. the plan is to add a "international" vinal decal to the blank covers. i hope someone can point me into the right direction. thx again guys :P
If you have anyone isn your area that builds engines, give them a call. They would know exactly where to get them. Most engine builders have access to a ton of information and are willing to help you out if you need a certain part.
Any pics of the scout? My buddy's gpa has one, green with the white stripes, all factory I think. Really cool truck!
Summit has the blank chrome ones for dirt like 30 bucks.http://www.summitracing.com/parts/SUM-G3301/?rtype=10
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
