Bring a case of beer over and let's roll!
Sounds like a good time!
I used my truck for some heavy hauling today, went and picked up a recliner. :lol:
It smelled funny so I hit it with some Lysol and wiped it down. Smells good now.
Missing my truck. I'm on the road this week, at Purdue now in a rental car with a weird smell. I did see a Ferrari 458 today which was neat- such a stunningly beautiful car.
My lights. Crappy cell pics 20130921_234324_zps1d6f323b.jpg20130921_234349_zps92c7001d.jpg20130921_234419_zps1ef3b316.jpg Sent from my Samsung Galaxy S4 using Tapatalk 4
Can you actually see with those LED's while backing up? I have LED's and cant see crap. I have to hold my brake lights to see anything. But they look awesome so I haven't swapped em out yet haha
Basically bought a whole new front end. Now I just got to put it together. 4y9yqahu.jpg Sent from my iPhone using Tapatalk
You should put in polyurethane bushings. Night and day difference in handling
My lights. Crappy cell pics Sent from my Samsung Galaxy S4 using Tapatalk 4
Yes I can. My truck is barely lifted. Yours on the other hand...
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Enjoy Purdue, thats my alma matar
Any particular brand you've had good luck with? Going to be doing some suspension work this winter, and my factory bushings are looking weathered.
Maybe I could make my own, made a bunch for the Baja SAE car last year. :lol:
Right now I'm debating ordering everything and doing a complete front suspension overhaul (-shocks & bearings, already done) which probably isn't needed, vs taking it to the shop and having them do just what's needed.
Edited by kstruckcountry
Do it yourself it is not hard at all. And you can replace everything for the price of them to install a few things.
I used Energy Suspension bushings. Come as a complete kit and perform awesome. Make sure you follow instructions on using the grease it comes with. Buy extra and don't be scared to use it. Just wipe off excess
Someone stole my two 13mm wrenches while I was at lunch. Put a real crimp on how much I could do. I ate at a good Irish pub called 9 Irish Brothers last night, started late this morning because the parking permit office had moved since my last visit and then the wrench thing. Rough start. :lol:
Letting mine rest easy in the garage so it won't turn 12k before its second birthday tomorrow...
Finally finished replacing all the wear and tear parts on my front end. Gotta love gm! Everything but the wheel bearings and shocks made it to 316k miles. Now I just gotta grease it up and get an alignment.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,087 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
