Not much has changed with either of mine gave them both much needed baths the other day and been daily driving the 86 more than the 06 lately for the hell of it. 77a5625bbdeee139e7bc99220f4152d9.jpg9d2672bdc99d70f60df021dc9b575d5e.jpg
Sent from my SM-G955U using Tapatalk
  • Like 3
Yesterday I rebuilt an 05 TrailBlazer cluster and a few GM FOBs, this morning I'm getting an 05 Envoy cluster to rebuild.
Both still lookin' good! :thumbs:
Truck has been in the garage and I’ve been messing with and driving to Cobalt. Parts for it came in today.
Just repaired a FOB ( 15252034 ) for an 07 G5 and programmed her car for it.
What special tools are needed for that programming
How long has it been side you've been on here? Seems like almost 6 months or so
Sent from my SM-N920V using Tapatalk
I use the GM TechII for these cars that don't have on-board programming.
I knew it needed one. But no codes from Gm are needed?
7
Can do it with any bi-directional scan tool. Doesn't have to be a Tech-II. My Autel will do it. Don't need anything from GM.
Edited by Jsdirt
Didn't say other scan tools couldn't do it, I just specified which one I use answering his question. ''What special tools are needed for that programming''
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,228 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
