But have you had your truck recalibrated
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Not yet I plan on doing efi live on it at some point but I ran 65 the whole way so that helped
Sent from your truck via Tapatalk
Old vs new. The pics don't even do these justice. The tread is as deep as a mudgrip.
625D3027-D414-4A0A-9075-334457931BA3-519
Before:
5010726E-B288-4375-8BD1-87B1D2C5DB34-519
Now:
AAD536F6-716D-45B4-ACB7-40CCAF03C6A5-519
The new tires don't squat much, so the truck is actually a little higher.
839F120C-9FA6-41D7-B578-675B55496347-519
Very happy so far. Ride is great, if anything a little better which is crazy considering the new ones are E rated. They are also very quiet. I'm impressed so far.
Installed Air-Lift bags and wireless one compressor on the pick-up 2day. All went pretty well 2nd one I've done we did my buddies last year. About a 2hr job.
Now if spring would sprung I could hook on to the 5er and go do some fishing.
Before:
Now:
Nice, I love Cooper tires. I think my next ones will be the S/T Maxx.
Edited by Daryl NHT
Nali is headed back to stock form.
Sent from an ice cream sammich.
Im guessing that's the name of your Denali. So all your parts going on the '13 with the exception of the Crosa....
I thought the length would be different since you're going to the XL
So I'm hoping the tuning is why I'm throwing misfire codes. Heard from Justin tonight. He asked if I was throwing MAF codes. Hoping to have the truck not misfiring at idle soon and my e-fans in by mid May.
Getting truck ready for show season.
Edited by takevin
Nice tires Danny. Good luck on the misfire issue Chris, if you can't find it just don't idle anymore. Me too Kevin. Do you have a gallery set up? Like to see more pics of your ride. :thumbs:
Edited by SILVERADOSC540
Pics after rescuing my buddy's jeep today... so much for a clean truck :lol:
Sent from my SCH-I535 using Tapatalk 2
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
