Took about an 85 mile drive... No drop in fuel mileage from the new tires. Supposed to get snow here soon.
How do they ride? I know my A/T3's ride great.
Stayed at home today. This week will be my first non-travel week this year. I'm gonna be stir crazy by Wednesday I suppose.
They ride a little better than the P metric Goodyears that I had. I think it's because you only need to run the 10 ply tires at half of their max pressure capacity, versus the 4 ply that I ran at 100% capacity all the time. The ATP's with the Bilstien shocks do really well 50 mph+ on the dirt roads and Interstate, the ATP's flex a lot less and the truck feels more planted and under control. Honestly I couldn't be happier so far, I'll be buying Cooper's again.
That's all I'll be buying from now on too.
I ran my errands and talked to Justin about my tune. Apparently I may have a small vacuum leak and will need to perform a crank relearn
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Changed the rear diff gasket that decided to die an early life. I replaced the gasket a few months ago and this morning it was leaking all in the driveway. I wasn't sure if the gasket was the culprit since it tore all to pieces but I replaced it with a new one. Oh and a heads up, if you buy a $6 gasket at advanced auto and it happens to bust or whatever, make sure you take every little piece of that gasket so that they can refund you cause if you don't and decide to instead take a picture of the torn gasket rather than hand them confetti then they will not replace it for you since they actually DO want your confetti so that they can throw it away in the back garbage. Kinda pissed me off but I held my aggression in, it was only six dollars........
Yea I gave up on Advance and Autozone their pathetic.
Out burning gas in the 6.0 and saw this. Looks pretty damn good
Edited by chawkins6789
There's a truck like that around here.
Paid $60 to get my tags renewed.
Sent from my DROID RAZR using Tapatalk 2
Edited by Pknitty86
I hate you. Mine is close to $300
Got tags for the bike, and new battery for t he bike.she fired right up.
Sent from my SCH-I535 using Tapatalk 2
Do you pay property tax?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
