I think my blower motor resistor went today. I can't use the "5" fan setting
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
If you lost five it is likely the high speed blower relay, not the resistor. Check the plug though as they do melt on the resistor harness.
Is that in the box under the dash?
power steering pump has a blown gasket or seal whatever so thats leaking
both wheel bearings need to be replaced
my amp needs to be hooked up again because i hit bumps and the bass stops
fml
the end
Washed, clay bar, amd waxed today... just to have it rain on ot a few hours later... I hate rainSent from my SCH-I535 using Tapatalk 2
Changed dash... Cracked near top left corner of airbag. Gm helped fix it, so it's all good.
Apparently everyone w a 2008 and up eventually gets the same crack.
michigans finally warm thats all i care about
This!
Wasn't with my truck but I went with a friend in his '69 Chevelle to a cruise night at the Halo Burger in Grand Blanc. Quite a few nice cars on display.
Edited by MikeNH
I love Chevelles. Very cold here today. Worked on outfitting an 07 Cummins with balebed and hydraulic pump. I'm glad my pickup is so easy to work on under the hood, it's a bit of a chore just to get off the belt on these Dodges.
That's one thing I've always liked about GM's Trucks.
mine went while the heat was on 5 the resistor melted and blew smoke into the cab it melted so bad that the fans stayed on i had to pull the fuse.. the resistor is under the glovebox on passenger side right in middle closer to door, go in unplug it if you need to, if you are under i believe 150,000 miles they will replace it for free since it is under recall
I'm at 117,400 as of yesterday. Does the box have to come off?
Nope, just drop your cover (no need to take it completely off, screw by console can stay) and it's pretty much right there. It's a pretty easy fix.
It pissed me off. 95 out had the A/C on cold and the fan on 5. Stopped at the gas station. Started the truck and no air blowing. Works when set to 4
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
