Hahaha yea I peeped and I quoted I won't reveal it here
Sent from your truck via Tapatalk
My guess would be HD front end. And if he's smart he'll put on a real bumper to protect it from deers. :jester:
Omg an HD front end would look sick on that beast! I can't wait to do it to mine in the future.
A HD front end would be the ultimate. But my recently built home and all that goes with it have drained me of time and most importantly, cash. Although my garage big enough for my steed is sho nice. I'll start a thread in e next day or two showcasing the newest mods.
I hear that from a lot of new home owners. I'm sure I'll know the feeling soon.
I have to put off mods for a while too many things came up. Gonna be tight for a couple months. All the extra gas back and forth to the hospital. I have to go to a wedding in Utah at the end of June. And now I need to get a new laptop for school. Mine won't charge.
I'm hoping my mom leaves the hospital soon. I didn't realize 2 teenagers ate so much until now. I'm the one who is feeding them and it isn't cheap. So many plans after I get caught up.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I need a new hood badly mines all chipped up looks like someone threw handfuls of rocks at it... Don't know why nobody's ever near me when I drive
How'd it look? How many miles or kilometers for our Canadian friends :lol:
Ryan
Nice man, I need to sack up and do the same.
Surprisingly easy mod to do...for the silvys at least. You should do it. Sooooo worth it.
I must have missed it...What did you do?
Ryan
15,600 miles. The magnet was full of fine shavings, and the fluid was somewhat dirty. The gears had a few real small pieces of metal here and there. Nothing terrible, but I seen enough personally to make me glad I changed it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
