Too Much Chrome?
Chris
Ah the ole GMC Cadillac, I see that all the time around here with old tahoes.
diamond plate steel bed cover. stick on hood port holes but he actually made them into vents. diamond plate window vinyl. just way too much chrome
To much for me but it ain't my truck. To each his own.
I'm not sure but I'm glad it doesn't have the GMC emblems anymore. Poor truck
Sent from my DROID X2 using Xparent Red Tapatalk 2
To each his own. I was actually thinking about wrapping my doors in that chrome edge guard, all the way around-maybe the hood and tailgate too. No. Not really.
I did get Line X today, the guy offered me the new emblem instead of the black and yellow that I've always had, and then pulled out this ugly black thing...he told me to trust him, so I did. Turned out pretty well.
  • 4 weeks later...
looks like autozone got their money outta this guy! This stuff is pretty common place around here anymore. used to make me laugh, but anymore just look the other way
Why Autozone, Is half that stuff even available there?
Sent from my iPhone4S
using Tapatalk
Not so much the diamond plate, but the fender vents, and bling bling letters are. At least at the ones around me, they seem to be quite popular, at least around me.
If the chrome does not come from the factory it doesn't belong. Trucks like this make mine look that much better, so it doesn't bother me lol.
Did your lowering kit come from the factory? The large diameter wheels? According to you, it does not belong.
How anyone decides to modify their vehicle is completely their choice. It is not right or wrong, it is just their choice.
The stab at the lowering kit wasnt at his point he said "chrome" the wheel argument has buoyancy
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
