Countdown to 5,000 Members!
Zane
Just a little over 50 to go!
C'mon everyone, tell your friends, lets get to 5k now!  :jester:
Are you kidding me?!  I thought it was just like 2000 not that long ago.   :eek:
Cool huh?  :thumb:
K1500, I love the sig...and as you know, people are stupid.  I loved the guy in the Cherokee sport who wouldn't get over when I was flying up with the siren going while hitting the airhorn and burst buttons trying to catch up to our Sgt. pursuing a car.
either stupid or deaf
btw it is now 26 to go  :fume:
    zibzer2
    zibzer2
  • Who's Online   6 Members, 0 Anonymous, 803 Guests (See full list)
