Tillur Posted May 31, 2012 Posted May 31, 2012 hey guys, I am looking to get more power and torque from a 350 what performance upgrades can I do? i'm on a fair budget of 2500 dollars, thanks. (Already has true dual exhaust)
Mckenzie Posted May 31, 2012 Posted May 31, 2012 Long tube headers, cam, bore it out, cai, and a chip Sent from my smartass iPhone using Tapatalk
Tillur Posted May 31, 2012 Author Posted May 31, 2012 that's what I was thinking... but with long tube headers, wouldn't you get little power gains on a pretty much stock 350?
GMstrong Posted June 1, 2012 Posted June 1, 2012 Yea you would be better off throwing a set of shortys on there that bolt right up to the stock pipes.Im in the same boat this is my plans,cam,Electric fan,and a tune probably from wheatley dont go for that hand held bs.I want to do a 383 stroker but the motor has no problems and has great oil pressure so i dont have a good enough reason.you really get the shorty headers first i did great improvement.
Tillur Posted June 1, 2012 Author Posted June 1, 2012 Yea i was going to get the whole comp cams package http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=K08-420-8, since i'm upgrading one part of the valvetrain, I probably want to improve rockers,lifters etc. And for the shortys should i get the stainless steel JBA's? http://www.summitracing.com/parts/GIB-GP102S-C/
GMstrong Posted June 1, 2012 Posted June 1, 2012 i summit racing which are actually pacesetter headers for 200 shipped.thats a retrofit cam which is not for roller blocks it requires a thrust button and wear plate.I was looking at the LT4 hot cam.
Tillur Posted June 2, 2012 Author Posted June 2, 2012 alright i think i got ya get a hydraulic roller and not a retro-fit
Tillur Posted June 3, 2012 Author Posted June 3, 2012 lol last question, so if i get a performance cam, should i get news rockers,lifters,pushrods etc?
Squirrely Posted June 3, 2012 Posted June 3, 2012 I always thought that if you went to a new cam that you should replace the rockers, lifters, etc. I would... it's not that much more.
GMstrong Posted June 3, 2012 Posted June 3, 2012 No need to replace rockers unless needed,Roller rockers are a nice way to reduce friction and and valve steam wear.If i do a cam.I do the timing gears,timing chain,lifters and check for bent pushrods if the pushrod are go they go back in.
Squirrely Posted June 4, 2012 Posted June 4, 2012 Do the rockers and cam not wear-in specific to each other?
Coolmaker Posted June 4, 2012 Posted June 4, 2012 Do the rockers and cam not wear-in specific to each other? No they don't....................
