Tire size stock truck
nh09z71
I have 63k on my OE Bridgestone's, so it's time to start looking at new tires. I've just about narrowed my search down to Cooper A/T3. The stock tires are 265/65R18. My truck, an '09 1500 Z71 is totally stock. Can a larger tire be put on with no adverse problems or rubbing? I understand the speedo will be off a bit, but I'm already a bit slower than my speedo reads now.
Thanks.
I am almost positive you can run a 275-65-18 w/o a leveling kit
I don't have any issues with 275/65/18 A/T3's that I just got about 2 weeks ago! No pics.... truck is STILL dirty! Lol Just haven't had time to wash the beast!
Chris
Called a few tire place today for prices....The place I am probably going to buy from tells me that the 265/65's are pretty much a P rated tire, while the 275/65's are a 10 ply tire. The price difference isn't all that much, but I'm wondering how much difference there will be in handleing and MPG?
I do drive on gravel roads quite a bit, and my truck is on construction sites every day, so the 10 ply should be more durable. I am also thinking of getting a travel trailer for when I am working on the road.
Going from a P-rated tire to a LT, 10 ply, E-rated tire is going to effect your handling and MPG. It will ride more stiff and your MPG will drop. However, those new tires will be much stronger than the stockers. There are plenty or companies that make a 275/65/18 tire in P-rated as well. Also, Cooper, Mastercraft, and Goodyear make 275/65/18 tires in a LT, but they're 6-ply, Load range C....which would be my choice, because they're stronger than the stock tires (6 ply vs 4 ply) but not as heavy as a 10 ply.
Thanks for your help. I called the tire shop back today, and he can get the A/T3's in the 275/65 18 in a C load range. They are only $5 cheaper than the E range tires, and he'll give me the E range tires for the same price. I told him my concerns over ride quality, and he says as long as I don't put too much air in them, the ride will be fine. And I'll have the ability to put more air in them if I need to for towing.
I cant seem to find a weight difference for the two tires online.
Buy the Cs. If you run E range tires at too low a pressure they can overheat and fail.
Got the new tires installed yesterday. I have about 250 miles on them so far.....and, while it's not a fair comparison of new tires with 16/32" to old tires with 3-4/32", so far the new ones are great. Pretty smooth at highway speeds, and not too loud either.
Going up one size to a 275/65R18 is no problem on the stock truck, and they look pretty nice.
Thanks for the help.
Pics might come later, traveling this weekend so i don't have tons of time.
As for MPG....hard to tell. It's been pretty warm here....been running the AC quite a bit. MPG has gone down some, but it's probably a combination of the new rubber and the AC being on so much.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
