Busy day
So had a bit of a mess after cutting down the old fence yesterday and had to do another load to the dump
After that I had a little running around to do with the wife before we got the windows tinted
And now it's time for some beer and steaks
And just for fun a pic of the new fence
It's always a great weekend to get a few chores done, but even better when you use the truck. Tinted windows look great there. I need to talk with my wife about getting mine done. When will the steaks be ready? So I know what time to be there.
Haha sorry mike but your too late for the steaks. Another thing. My wife was the one who made the appointment for the tint. Blew my mind lol
You had one hell of a weekend! and to end it with beer and steaks.. Cheers to that
