Battery Upgrade - Need the strongest battery in stock location in 08 S
Hey guys, I bought a Kinetic HC2000 that handles up to 2000 watts and 102ah from my car audio dealer/friend for $145. I had doubts it would fit, but for $145 for this battery is just something I couldn't pass up on.
So my alternator arrives at his shop tomorrow so I will be installing my Mechman 270a H.O. alternator and my battery. I didn't want to replace my stock battery, because it was recently replaced about 6 months ago, but I know I can't add an AGM battery to a spiral cell battery. So its either
A) keep the weak stock AC Delco @ 615 cca and add the biggest Optima Yellow Top I can fit in the auxiliary battery tray. Stock Batt: 615 CCA + Optima: 750cca = 1365cca
B) Purchase 2 AGM batteries replacing the stock battery. Was going to go with two Kinetic HC2000's since I already paid him for the battery. If it doesnt fit, I'll get my money back. So now I have searched for other alternatives and found that I can run two Stinger SPP1200 that are rated for 2400 watts each for a total of 4800 watts
The Kinetic HC2000 is measured at 12"x6.5"x8.2" ($145 for the first battery and $255 for a total of $400)
Stock Battery I measured today @ 10.75"Lx6.5"Wx6.75"T
2nd Battery tray measures at 11"x8"x8"
Stinger SPP1200 measures and fits both trays at 6.75”H x 7.75”W x6.5”D ($196 each x's 2 = $392)
Optima Yellow Top D34/78 measures at L-10 in.; W-6 7/8 in.; H-7 13/16 in. ($200, but wouldnt be enough with my stock battery.)
So I am just wondering what everyone else's experiences have been when upgrading to a 2 battery setup, primarily for car audio purposes since we are looking at audio batteries.
Any input guys?
Nevermind. After more searching with various tag words, I found my answer. Looks like it would be an XS3400. The capacity is a bit low though. I was expecting alot more out of such a stout battery. Was trying to get a little closer to 100ah.
Thanks, I appreciate it.
If you are in the DFW area, I can refer you over to the body shop that did it. Now that they have a bit of practice, they can get it right. I know the owner of the body shop so I got a good price.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
