P0452
dlstewart01
Started the 2005 GMC this morning and the fuel gage did not work and a low fuel message came on. When I parked it last night it had a half tank of fuel. The check engine light was also on.
I pulled the code and it came up P0452. Thats for a fuel tank pressure sensor. The truck runs normal. I drove it for about 5 miles with no issues.
I have not got into it yet but since the fuel gage is not working as well do you think I need the fuel pump/sending unit or just the pressure sensor? The pressure sensor is mounted on the pump unit.
Could be a wiring/ ground problem. I think both of them may share some same wiring. What do the experts say.
Put a GM fuel pump module in it
It has the original fuel pump on it and it works perfect. There is a problem with the fuel tank presure sensor and the fuel gage that showed up together.
Before someone brings it up, I have an extra cluster that I know the fuel gage works. I will swap them out to rule out a bad stepper motor. I was just wondering if some one else has had this problem.
Thanks
The code pulled is PO452...fuel tank pressure sensor. The local dealer told me to replace the sensor. He said the fuel gage was a seperate matter. i don't think so. I could be wrong but I don't think so.
I scanned it. I just ran it by their tech to get his opinion.
I may have to get a diagnosis. I was trying to save a buck. I am retired and don't have to drive it every day so I got time.
im adding the code ,its hard to figure out the diag trouble tree at the bottom ,,answer to yes is first then no is second ,,it then sends you to another line,,,a scanner is needed of course but a little info doesn't hurt ,,,,PM me if ya want ,i can explain it further or a phone call ...i want to help bud as the possibilities can be disastrous financially if the wrong part is installed as you can see in the tree,,
DTC P0452
Circuit Description
The fuel tank pressure (FTP) sensor measures the difference between the air pressure or vacuum in the evaporative emission (EVAP) system, and the outside air pressure. The control module supplies a 5-volt reference and a low reference circuit to the FTP sensor. The FTP sensor signal circuit voltage varies depending on EVAP system pressure or vacuum. If the FTP sensor signal voltage goes below a calibrated value, this DTC sets.
The following table illustrates the relationship between the FTP sensor signal voltage and the EVAP system pressure/vacuum.
FTP Sensor Signal Voltage
Fuel Tank Pressure
High, Approximately 1.5 Volts or More
Negative Pressure/Vacuum
Low, Approximately 1.5 Volts or Less
Positive Pressure
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC?P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
Conditions for Running the DTC
Conditions for Setting the DTC
Action Taken When the DTC Sets
Conditions for Clearing the MIL/DTC
Test Description
The number below refers to the step number on the diagnostic table.
5 This step tests for the proper operation of the circuit in the high voltage range.
Step
Action
Value(s)
Yes
No
Schematic Reference: Engine Controls Schematics
Connector End View Reference: Engine Controls Connector End Views or Powertrain Control Module Connector End Views
Did you perform the Diagnostic System Check – Vehicle?
Go to Step?2
Go to Diagnostic System Check - Vehicle
2
Did DTC?P0641 or P0651 fail this ignition?
Go to Diagnostic Trouble Code (DTC) List - Vehicle
Go to Step?3
3
Observe the fuel tank pressure sensor parameter with the scan tool.
Does the scan tool indicate that fuel tank pressure sensor parameter is less than the specified value?
0.1?V
Go to Step?5
Go to Step?4
4
Did the DTC fail this ignition?
Go to Step?5
Go to Testing for Intermittent Conditions and Poor Connections
<a href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=1398849&cellId=30498&pubObjSyskey=2810312&from=sm&pubCellSyskey=347017&deliveryEffectiveDate=Jun+1%2C+2012#td05">5
1. Turn OFF the ignition.
2. Raise and support the vehicle. Refer to
Lifting and Jacking the Vehicle .
3. Disconnect the fuel tank wiring harness at the fuel tank harness connector.
4. Connect a 3-amp fused jumper wire between the 5-volt reference circuit of the fuel tank pressure (FTP) sensor and the signal circuit of the FTP sensor.
5. Turn ON the ignition, with the engine OFF.
6. Observe the fuel tank pressure sensor voltage with a scan tool.
Is the fuel tank pressure sensor parameter greater than the specified value?
4.8?V
Go to Step?8
Go to Step?6
6
Test the 5-volt reference circuit of the FTP sensor for an open between the fuel tank harness connector and the control module. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step?12
Go to Step?7
7
Test the signal circuit of the FTP sensor for a short to ground, or an open between the fuel tank harness connector and the control module. Refer to Circuit Testing and Wiring Repairs .
Go to Step?12
Go to Step?9
8
1. Remove the fuel tank. Refer to
Fuel Tank Replacement .
2. Inspect the fuel tank wiring harness for the following:
• Damaged wiring
• Poor connections
• Broken wires inside the insulation—Refer to
Go to Step?12
Go to Step?10
9
Inspect for poor connections at the harness connector of the control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step?12
Go to Step?11
10
Replace the FTP sensor. Refer to Fuel Tank Pressure Sensor Replacement .
Did you complete the replacement?
Go to Step?12
11
Replace the powertrain control module (PCM). Refer to Control Module References for replacement, setup, and programming.
Go to Step?12
12
1. Observe the Freeze Frame/Failure Records for this DTC.
2. Turn OFF the ignition for 30?seconds.
3. Turn ON the ignition, with the engine OFF.
4. Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records.
Go to Step?2
Go to Step?13
13
Observe the Capture Info with a scan tool.
Have any other DTCs not been diagnosed?
System OK
Thanks so much for your help. I can see where this may not be easy. I don't want to throw parts at it or spend money I don't have to.
I will get back on it tomorrow. I may have to get the dealer involved. I can change out the semsor if I knew that was it. I still believe the non operating fuel gage is also part of this problem. I will change out the cluster tomorrow and rule that out. Thats an easy one.
Thanks again.
Well eliminated the cluster. I had my orginal cluster that I took out when I bought the truck and put a cluster with a trans temp gage in. This cluster only has a few miles and I know it to be good. Put it in and fuel gage does not work and low fuel message.
Now I also have code P0463 fuel level sensor circuit high imput. I guess thats causing the fuel gage to not work.
I was hoping that some one had had this problem or a dealership person had seen this before.
So it looks like I need a fuel tank pressure sensor and a fuel level sender. heck might as well get a new fuel pump. The pump has to come out to replace the sending unit.
Oh yeah, the trucks runs perfect.
