gear ratio/tire math, what ring gear do i have?
Very curious to know how the math goes to figuring out how much your gear ratio is affected by tire size?
If i have 4;10,s andd run a 33" tire.. am i ddown to 3;73.. or a 35" tire..does it go ddown to a 3;55?
Finally with 4;56,s in and a 35" tire how will my rpm,s be?
Also how do i determine what ring gear i have, 10.5 or 11.5. Its an odd shaped 14 bolt, w/4;10,s and an 8.1/allison combo up front..
I thought that the big blocks also had the 11.5 rear? I know that if you look at the numbers that is why the big block Suburbans got the 4L85E vs 4L80E. In the pickups I know that you could also get a Ally trans behind a Big Block and he tow ratings were the same for both the D-Max and Big Block.
    tonyb2760
    tonyb2760
  • Who's Online   5 Members, 0 Anonymous, 523 Guests (See full list)
