Stock 2003 1/2 2wd Silverado.
Had new tires put on and anyplace that there was lead wheel weight there now is corrosion on the rim. I know the answer is a resounding "NO"! But, is there anyway to make this look any better? Spotless truck and yes it is a 2003, but the wheels really tick me off now.
Can you polish them up with a dremel tool, or something similar and touch up the clearcoat?
no you cant fix it. almost all GMT800 rims corrode at some point. but then again people should put the wheel weights on the inside. i tried to fix the corrosion and you can make it look a little better by sanding it down
Sand them down and refinish. Mine looked like $h!t so i stripped them, sanded and painted black. I would assume with some time you could do the same and clear coat them again. As stated above, weights on inside only.
pisses me off when people put them on the outside.
i think the only GMT800 stock rims that look good painted black are the ones 8.1HD/ALLISON has.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
