Hey guys I'm going to add a leveling kit on my Sierra with already a lift and add bigger blocks in the back, to stop that tire rub! Do I need anything else to do this or just the leveling kit + the bigger blocks to even it out PS I'm gonna take out my body lift, I don't really like the look of it!
agreed i wouldn't do a big leveling kit on the bds kit. basically you bought a 4 inch kit that has a 2 inch leveling incorporated in it already so adding more will really really screw up your angles. i would deff recommend the 1.5 body lift as well
Well I found out I don't have any blocks at all in the back just springs so would it still be bad for my angles? Or are you talking about the front here?
Anyways hahaha, well thanks for the advice guys! I might try 20's with different back spacing because I have a 1.25 RC Body Lift and it barely rubs with that, only reverse going left!
Try trimming your splash guards, or drill a couple small holes and zip tie them back a little. If you do it right, you will never see the ties and it will help clear the tires when in turning. Just a thought.
Definitey dont remove your body lift. You can't make up the difference with a leveling kit. You can get away with a 1" leveling kit, especially if your front end has settled some. I have one and my angles aren't bad.
Who makes a 1" Leveling kit? If that's the case I will keep the 1.25BL + 1" level + 1" blocks in the rear cuz I have none, so if my math is correct that equals 8.25in of lift.. I like the sound of that :)
    JustusTX
    JustusTX
  • Who's Online   5 Members, 0 Anonymous, 568 Guests (See full list)
