Door Handle Broke-Need Help
Okay so the spring mechanism on my exterior door handle assmbly broke. Got the replacement and put it on and reconnected everything...or so I thought. There is a rod witha odd shapped metal piece at the top of the door inside. It connects to the door handle but only by a small plastic nail/harpoon shaped retainer. It still rotates freely which I found odd, so i tried opening the door from the outside and it has the spring tension as it should but it does not open. Any ideas?
is the rod that goes to the door catch hooked up ? the rod pushes into the plastic clip on the door handle then attaches another plastic clip on the catch.
the handle will have spring tension on it even if its not hooked up to the catch because of the spring on the handle
it sounds like you don't have the rod connected to the handle properly. I am not familiar with the GMT900 inards (I am familiar with the GMT800s), but your best bet is to pull the door panel on the opposite side and use it for a reference. :thumbs:
I went and looked it over and figured it out. I had connected the original metal connecting piece (circled) to the new metal piece. Essentially I had to connection points when I should have had just one.
Removed the original and connected the new and all good now. Makes ya feel stupid but uts Friday so I feel like celebrating.
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
