Door panel question?
I've got an 11 GMC SLE and the only thing I hate about it is the placement of the door handle, I like where the SLT handle is has anyone swapped out the door panels and handles or do I get to be the test subject? :jester:
it can be done , one thing I'm not sure of is how the dash lines up after you go from your SLE to the SLT panels ,
We got a SLT door in for a job at work to be installed on a SLE or less trim level group. You will need the longer cables to go from the door catch to the door handle as well as moving clips into different locations to match the new door panel, these are the clips where the bolts go into . Your other problem may be the proper window switches to match the door panel , if you have the wiring for DL3 (data bus) type mirrors you will be good but if you have the wiring for the DL8 (hard wired) mirrors it may not work
I have 1 Black passenger side SLE door panel if you need one ...
