Need some help from some of your for a school project
Chris
For school I need to write logic for a small program. This program will encompass GMT-800 and 900 trucks. It's about modifications. So what I'll need is step by step install with pictures of the steps and instructions, part numbers, where to buy and price. Could be simple like intakes, level kits, shock swaps.
Any help is appreciated. I'm going to try to get a higher grade by coding it and actually making a program
LOL...........no disrespect but it's your project to do so don't count on other people to help you get a good grade. If you put the time into YOUR paper and do the research, you'll be given the grade you deserve...good luck with the paper.
It's not required that I do it. I have the basic logic done which is what's required. With school I try to be a perfectionist. The program isn't required but I would like to have it done. I can get the info off the forum if I really needed to. But I'm basically asking for permission to use peoples information and going to give them credit in the program.
If I can write a program with 2 or 3 items it will allow me to test my logic
Go to the how to section I just did a writeup on adding AAC footwell lighting
Ryan
Originally I was going to grab stuff from the How to, but I wanted to get permission before publishing peoples write ups in a program even though it will only be used in class
feel free to use mine
Thanks Ryan, Right now I'm just struggling with the coding. It's going to be real basic, just functional. I'm trying to find the rigt language to code in.
Not sure. I got Java through school but it didnt install right. For now I am using VisualLogic to get the sequence correct and coding in BASIC using Microsoft Visual Basic
