Wanting to run 3 amps need help on parts
Chris
Is there a distribution block I should use or run everything straight to battery. Also wire size details. I will be running a 750 watt mono amp for my subs, a 100x2 watt for my front doors and a 50x2 for my rear doors
sell the small front and rear amps and buy one amp that is bigger would be my opinion. the only way i run disto blocks is if i'm running 0 gauge to the back. with that small of a set up you could run 4 gauge back, 4 off of that to the 750 and 8 gauge to the two smaller amps.
I didnt know what my best option is. I havent purchased anything yet. I only have upgraded my front and rear speakers. They are rated at 100 each RMS for the front and 50 for the back. Kinda screwed on the back because I have to run 4x6's. I got Polk DXi 4x6 plate speakers for them
So how do I deal with the different power requirements? I dont want to underpower the front doors or overpower the rear doors
why are you doing this? where are you going to put all of this nonsense?
ive have a friend with an GMT800 ext cab and has all of his speaker crap bolted under the seat
I have 2 subs under my back seat right now. the amp is mounted on the back of the cab behind the seat and that is where the new ones will be as well. I did my front speakers and will do my rears hopefully tomorrow when I get a new soldering iron
did you take your rear seat out to mount it there? i tried to get the bolts holding the rear bench on off and they will not budge
I didn't do it, a shop did when I lived in Florida. I believe they pulled the seat. Ill find out in a month or so
Your amp will run the power as it is meant to do. It doesn't matter the rms as long as the amp isn't pushing over the speakers Max power it can handle. Also, an amp,or I should say the top of the line ones, only run 80% efficient either way so I wouldn't be worried about your setup.
so with Polk DXi 6500's rated at 100/300 in the front and Polk DXi 460p's rated at 50/150 in the rear would I be good with the kicker ZX350.4 which puts out 90x4 at 2 ohms.Polk says the speakers are 4 ohm so what range should I be looking at?
Either one of those amps will be fine for those door speakers. Really, you will notice a hell of a difference from the stock h/u.
I changed stock HU to a Pioneer AVH-P4400BH. I think Im going with the Kenwood for my doors. I have to find one for my subs. I know both are getting 4 gauge wire. So far looking at the Kicker ZX750.1 or Kenwood KAC-9105D to power 2 JL 10" W3 4 ohm speakers
Get the kenwood. I am a kicker guy myself but I think they like to overprice their amps. I actually have that exact kenwood right now powering my two 10in Kicker cvt's and it sounds perfect. I had an mtx jackhammer before it, I had two different kickers before I had the kenwood so I had the setup rated for the old subs, now that I have swapped amps, it has been a world of difference and its always a plus for fan cooled amps! Here is the site I use for all my electronic needs. They usually are priced better than Crutchfield and most of the time have free shipping. http://www.sonicelectronix.com/item_22574_Kenwood-KAC-9105D.html
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
