02 GMC Sierra 1500 ext cab
I have everything past the cat. for sale.  Its one piece and bolts onto the cat.  I live near pittsburgh pa in a town called butler.  Let me know if u r interested.  It only has about 5000 miles on it.
:popcorn:
So what did you replace it with?
Curiosity has the best of me as I'm looking to put a aftermarket exhaust on my truck......
Did you go with the magnaflow?
a little offtopic but do you have pics of the new exhaust on your truck?  Notice any performance gains?
Thanks
No I dont have any pics yet.  Hard to get it cleaned up this time of year.  :cheers:
I definetly notice a gain throughout all rpm's.  It also is not very loud (louder and better sounding than stock though).   :cheers:
