Pix of your Hunts this year?
Spurshot
I know lots of seasons have openned, especially in the northern states. Dove season has come and gone. Let's see some pix.
Went hunting this weekend for waterfowl opener and grouse. Didn't take any pictures though. Got a blue winged teal the first day and one the second day. Also got a green winged teal the second day. Didn't get any grouse though, seen three but didn't get them.
  • 3 months later...
Well here is the 2 we got this year. My son got his first deer too! I was soo excited!
And here is a little 6 point I got on the last weekend. Been watching them all year and decided to take this one.
Congrats to you and your son. Its great to see someone bring their kid out hunting.
Thanks! I got him a little Remington 770 .243 Youth model for a early Christmas present this year and he loves it. Great gun for a kids imo!
  • 4 weeks later...
A little late but better late than never. We had a great day that day!! Even got the GMC in the picture
Great day, hell! lol Thats more ducks than I have shot in the last couple years. Where you live at? Southern IN is not known for its duck hunting, and the birth of my 1st child cut season short this year.
I live in a central Illinois about a hour south of Chicago right on the Illinois river, and yea that was a good day but that was the only real good push we had all year...
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 489 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
