I have sinned
k1500chevy97
Well sitting here watching TV tonight and BSing with a few people on AOL IM and I see this Ford commercial come on
Well this looked like a new one so I decided to give it a look , Well anyway the started out showing some ranchers with their livestock trailers on the back then went to the hwy dept and their flatbeds but the next one shocked me ....
It showed me and another guy from our dept washing R-9 and posing in front of it .
When I seen this I was like WTF!!!!!  :chevy:  :)
Then I thought to myself when had anyone taken a pic of us ..... back in september a camera crew come by and asked us if they could shoot some shots of us washing it and a final shot of posing in front of it .... not thinking much we said sure they got their shots and left .
Someone shoot me now !!!!!!
I am going to be getting all kinds of #### for a long time because I drive and bleed GM .  :cheers:  :cheers:
K1500,
Why do you always post pics of fire engines and ambulances and tractors?
Because those are my jobs , my intrests .
Other people post pics of cows , lowriders , big wheels, corvettes and even fords :eek:  so im like what the he!!   :smash:
They didn't tell you guys what they were shooting it for?  ???
I'll keep my eyes peeled now for it - actually it seems familiar now that you mention it!  Hey, you're famous, or should I say "infamous"!!  :smash:
Unless you are in central washington sometime within the next few months you probally wont see it .
It was one of the local dealers commercial.
I 've got a Glock 21 45 and the wife prefers the odel 19 9mm. I am thinking about having the trigger pull changed from the stock 5lb to 3 1/2 lb. Just wondered if you have done any mods on your gun.
Hey Ryan  I seen that ad on TV last night I must say you and Mr. James looked sharp standing next to that ford  :smash:
Hey I've got a G17 that I've modified....
Definatly change out that trigger.  The 3 1/2 lb trigger is a lot better.  I've also pushed out the factory sights and put in a real nice set of trijicon 3 dot night sights.  Then I added a laser  pointer that is built into the guide rod.  Very nice and acurate.  Nothing like staring into the laser..  Like a deer in headlights.
Just my .02
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
