Can I plow properly with the truck lifted?
yukon25008.1
I appoligize if this sounds stupid.. But i had an 05 sierra 2500 with a 3" body lift and a western uni mount, And everything worked fine.. On this 05 sierra 3500 Id like to do a 6" suspension lift with 35,s.. Is there enough adjustment in the plow mechanics..That the plow will reach the ground completely? Thanks,
i know some guy who has a 7.3 ford, not sure what year, but it has some kind of lift, definatley a 6-7" susp lift but his plow mount looks like it was extended like a foot. pretty ugly but i guess it works
You know i might be better off finding a decent 96-99 sierra reg cab long bed..plow truck,
especially if your salting.. def get another truck. you can find 2500 and 3500 GMT400 with plows for dirt cheap. and you wont need to worry about banging it up a little bit either
  • 1 year later...
I do it with a 2011 had to make custom plow drop plates , Just used it last night in a Central NY snow storm. The truck goes great with the Trail grapplers
You have to make sure the A-frame is level. I'm pretty sure you'll have to weld "ears" on where the it mounts to the lift assembly.
