Truck Weight
varmint2506
I ran my truck across a set of scales at a job site we are working at. She weighed out at 5540 lb. without me in it. I don't have a tool box and the bed was empty. That seems a little heavy to me for a extended cab short bed. What do you guys think? Registration has it at 4100 ew.
My registration also lists at 4100 lbs, but 5500 lbs actually sounds about right... I remember after I got mine, I did a search for the curb weight of SCSBs and I think 5500-5800 lbs is about what I came up with... :smash:
Shanners sounds about right for a 2500 crewcab but the 1/2 ton xcabs sound high to me.  My 1500 reg cab 4x4 weighs 5050 with me (165 lbs.) in it.
It seems kinda high. I guess the scales I used are accurate. They use them to weigh freight trucks at a distribution warehouse.
My '97 Tahoe 4x4 4dr LT weighed in at 5,300lbs, so it's right in the ballpark.  Also, how much gas did you have in it.  I think a gallon of gas weighs around 7lbs (or something like that) so the difference in a half tank of gas (some 15 gallons can add up).
FYI, I wouldn't take too much stock in what the registration stuff claims other than your name, addy, and the actual vehicle info itself.  Otherwise, they're just averaging what the common weight's, power per liter (or whatever form of measure they use), etc, etc over hundreds of thousands of vehicles from all manufacturers that they have registered on their system.
I've calibrated a few scales (older manual not electronic
) and then proof tested them. 10% was not uncommon at the bottom end (10k lbs.), But accuracy was 2% at midline (30k lbs.)These tolerances were considered acceptable by the Bureau of Weights and Measures.
Depending on the scale, your truck may be too light for an accurate measure.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
