  • Replies 55
Posted 3x. Taken care of. But as for vehicle use, I have only used it on door hinges and the spare tire winch
some people like to used it as plastic polish and trim polish.. dont really know why. i use WD40 for what its meant to be used for, lubricating things and i spray in on rusty things to help break them free
For rusty things I prefer a can of good ol PB
i usually use PB too, always have that or WD40 lying around.
they just came out with white lithium WD40 which is awesome for chains and lubrication things because it dosent dry up or just soak in like normal WD
I lubed my tow mirrors with other brands of white lithium. makes them a lot easier to slide in and out
lubed the plastic?
Yes. sprayed a little on there while extended. Mine were hard to pull out and push in when they were new
I had to a couple times when moving the travel trailer. The horse trailer is wide enough that normal mirrors cant be used, the tow mirrors are perfect when retracted
I use it to lube some things. But to get stuck bolts out PB is the way to go
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 924 Guests (See full list)
