I have never used PB but I have noticed wd40 didn't seem to work very good for stuck stuff but it does for everything else, I even use it to wash grease and I've seen it used to get tar off of your hands before
  • Replies 55
Kroil is a great product. Beats PB IMHO.
I can't remember the last time I used WD40
Heres one that most people never thought of, I knew this old lady about 70ish she used WD-40 on here arthritic joints. She swore that it worked better than any drugs off the shelf. Go figure.
I believe WD 40 was actually designed as an electrical contact maker. I kind of keep away from putting it on my truck because it catches dust. But it's good for lots of other things.
Dielectric is kind of contradictory because its an insulator but works to keep the contacts clean and free of moisture. In my early mechanic years I worked on an old S-10. Changed plugs and truck ran like crap. My uncle told me to check it running at night for arching and spray WD-40 on all the boots that arch. Sure enough I had a few arching, plug and coil side of wires. Ever since whenever I check change plugs I spray some in there. The boot connects tight enough to make proper contact but WD-40 keeps out excess arching. Works same as the grease you can get at auto parts store.
I only use it on the inside personally I try to keep it off the outside since it will drip on the engine. I spray just enough to coat the inside.
I've heard of using grease but never wd40 for that maybe ill have to try it. So you can use it inside and outside the boot?
Use the grease. Better in several ways
Lots of myths out there about the "amazing properties of WD40". Like most people I have a can in the garage, but I rarely use it. It does work great on my combination gate locks
wd 40 I dont even think its a penetrating oil . All good people with a wrench I know never say postive things about Wd40 they always mention a other product that works alot better.
Yes it is a water diplsplacer and its best use I found is on squeaks other than boots. I still use PB or Liquid wrench if something is rusted fast.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
