Adam's 2012 Christmas Sale
MERRY CHRISTMAS FROM ADAM'S PREMIUM CAR CARE!!
USE THE CODE HOLIDAY12 TO TAKE 10% OFF STOREWIDE!!
GOOD ON ALREADY DISCOUNTED KITS AND ITEMS!!
GET FREE SHIPPING AND A FREE ADAM'S HAT WITH ANY PURCHASE OF $99 OR MORE*
Great Gift Ideas For Any Budget with new offers being added throughout the holidays!
Check back to see the new deals!!
Click Here for Gift Ideas $50 or Less
Click Here for Gift Ideas $100 or Less
Click Here for Gift Ideas $150 or More
NEW PRODUCTS!!
Adam's is an Official Lloyd's Custom Floor Mats Dealer!
Fully customize and order your floor mats in a variety of colors, materials, edging, even add custom embroidery RIGHT ON OUR SITE!
100% Made in the USA... the finest custom floor mats in the business!
The Tail Bone Creeper Seat... the only rolling seat of its kind!
NEW!
Vac N' Blo Compact Wall Mount Vacuum... 4 horsepower enclosed fan... tons of attachments for interior detailing! Sure to be your new favorite detailing tool.
Back by popular demand, for the Christmas Sale only... Adam's Flex Upgrade Kit!
NEW! Adam's Premium Metal Polishing Towels - introduced after getting feedback from customers with aftermarket accessories made of softer metals like billet. Super plush for safe polishing even on the softest alloys, gray fibers won't show ugly metal polish stains.
GREAT GIFT IDEA! Get a FREE 16oz Detail Spray and Single Soft Towel with a $100 Gift Card Purchase!
NEW! Adam's Deep Clean Tire Scrub Brush!! A short handled tire scrubber with aggressive bristles to give your rubber a deep cleaning. Available in a money saving kit with 36oz All Purpose Cleaner as well.
NEW! Adam's Detailing Guide Garage Poster - Officially Licensed by General Motors for Corvette & Camaro!! This high quality, full color, poster features Adam's line of Officially Licensed Corvette & Camaro Car Care Products in a step-by-step guide to the basics of shine! This poster will look great in any garage, workshop, or detail bay!
*Offer expires 12/25/12 at midnight. Free shipping valid for the continental US only. Free hat offer good while supplies last.
The tailbone seat is awesome I have one and use it all the time
Ryan
If you need that perfect Christmas Gift December 19th is the deadline to get your order in for
Guaranteed Ground Delivery! Don't miss out on the great deals or FREE Standard Ground Shipping!!
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
