GMC vs Chevy bed rails are they the same?
So I'm looking to get a campershell for my 09 silverado 1500 cc. Found one for a gmc same year but want to make sure it will fit. Thanks for any info you have
I don't know about a campershell,but I can tell you that the bedrails themselves are different,I know bedrail protectors are different,and will NOT fit between a Chevy and a GMC on the GMT900 trucks.
Rich, really? I now the fender flares on gmt900 are different between gmc and chevy, but I figures the rest of the beds were the same. I know you are the expert and would know. I learned something today... :)
Yes,the GMC bedrails are wider.
Bed rails are different. I got a set of protectors for my 2010 gmc and they gave me the Chevy ones by mistake. Didn't fit. Two different part numbers.
Furthermore, GMC & Chevy bed covers will not interchange on this bodystyle. Just like the tail lamps are different.
It has to do with the rear fender flaring on the beds. Just look a NBS Chevy Silverado parked next to a NBS GMC Sierra, the Chevy flare nearly takes the WHOLE bedside to stretch it out. The GMC's have a simple curved arch above the tire opening..... :crazy:
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
