Grills
RyanbabZ71
  • 3 weeks later...
BRINKMAN.
Home Depot/Lowes's/Wmart.
$99.00 - just as good as the fancy ones. Just not as many options.
It's been my experience that a $200 gas grill will last about as long as $900 gas grill. I've tried both. The more expensive gas grill will come with a better warranty but if (after 7 or 8 years) the company no longer manufactures the burners or other parts you'll be asked to try to rig the new parts to make them work. My current grill is a $200 Brinkman from the big orange store. I've got 4 seasons on this one and hoping for 2 or 3 more. The $900 grill needs to last 4 1/2 longer than the $200 grill and that just ain't gonna happen.
Mike
I'm in the market for one again. I want 2-4 burners and an extra burner. It will be outside 24/7. Looking at Webers and Charbroil. Kinda shopping for the best price right now.
mine stays outside uncovered 24/7 I will grill on it when its 15 degs and snowing. Sadly to replace the 3 burners and the little flame cover things along with one grate its more the 1/2 a new grill
Sent from my SCH-I535 using Tapatalk
Yep freezing temps can't keep me from grilling. On the current one the actual body of the grille is rusting, in addition to the hoods and grease trap.
The Brinkman we have has 4 burners and a side burner. We rarely use the side burner...most days it's just too windy. One feature I like is that almost the entire bottom is a slide out tray. While the tray has a little drain cup, sliding the whole thing out makes it pretty easy to clean. It sets out on the deck but I do have a cheap vinyl cover on it.
Mike
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,235 Guests (See full list)
