Brake fluid change interval
I last flushed my brake fluid about 30,000 miles ago. It's been about a year and a half in a dry environment (desert southwest). Should I go by mileage or time before changing the fluid again? I was thinking 3 years between flushes.
Just FYI...
According to a certain consumer magazine, brake fluid should be changed every two years regardless of vehicle mileage.
Most will claim that it is a waste of time and money. However, brake fluid is hydroscopic, and water will naturally collect in the system without it never being opened. Water naturally forms from condnsation within the brake lines as the brake fluid gets rapidly hot then cools. Now last time I checked, water does not perform well under hydraulic pressure, and it also shortens the life of calipers and abs modules. Furthermore, most vendors (such as BG, Valvoline, and etc.) offer hard part component protection plans if an associated part has failed after having their flush performed on a vehicle. Flushing your brake system gives you improved stopping performance, and I beleive that it is the Department of Transportation that recommends it being changed every 2 years.
  • 3 weeks later...
In 2009 when I was doing a full brake job on my truck I noted my brake fluid looked pretty dark so I went ahead and changed it then. I've used that as my guideline, if fluid looks like crud I changed it. I just did my front brake again late 2012 and fluid still looked pretty good, and I live in a high humidity area. Personally if fluid looks good and no issues with brakes, leave it alone, if fluid looks dirty, cruddy, change it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
