Power Lumbar Pillow Not Inflating
For the past few days my seat has felt out of position in my back. I tried to inflate the back of the seat but felt no change. Once I got home I got out of the truck and tried to do the same thing but couldn't see or feel anything happening. I hear the motor running but theres just no inflation. So to compare I went to my passenger seat to see what it would do. Pushed the button...inflated perfectly, then deflated with another button press. Decided to try it again and it inflated for a couple of seconds and I started hearing a hissing sound (my guess is air escaping) and of course now neither seat is working. The motors will run however when working properly the seat would get to max or min position and then shut off. Now the motors will continue to run as long as the button is pressed and will not shut off. My guess is that since the system is an air inflated system, both "air bags" have somehow been punctured or developed a leak, and I'm also guessing the system is built around a pressure switch which would normally cut the motors off when a certain pressure is reached. Well since the system can't build pressure the switch doesn't engage resulting in the motor continuosly running. Has anyone else experienced this issue and if so what did you find out. I have an extended warranty but I'm concerned that this won't be covered. If any of you have experience taking the seat back off to gain access to the internal parts how difficult is that to do and how do you do it. Thanks in advance!
On your 08 Sierra? I didn't know they went to air lumbar, used to be a wire grid support that moved. They had springs, or the frame, that would break after time. You should be able to partially remove the seat cover to inspect from the back of the seat.
I'm not 100% sure if it's air or not since I haven't actually torn the seat apart. I'm just guessing based on the hissing noise that I heard and the way the system seems to work. I know the vehicle with power seats (like mine) have a differnt setup than the one with manual seats. My truck is an 08 SLT Z71 with the two front bucket seats and center console (no middle seat).
If your extended warranty is "new car" or premium you're probably covered after the deductible, if it's drivetrain only you're probably s.o.l. the deflate button should stop the motor. Good luck.
The warranty isn't new car as I bought the vehicle used. (well it was actually my dads that he bought new, then traded it for an '11 and I wound up buying it but added the extended coverage from Olympicare). The motor stops whenever I realease the button.
Could be a bad air hose too, from the pump to the air bag bladder, on LTZ style lumbar seats.
You would need to tear the seat down, covers, etc. to find out though.
I'm betting that "off brand" extended warranty will not cover lumbar seat parts too.... :nonod:
There is No Bag or Air line. This is the Metal Grid as Ron stated above. Prolly a bad adjusting motor. Pop open the seat back and you should be able to see all the parts involved.
According to a buddy at our local parts department who pulled up everything by my VIN number this IS an air system. There is a bladder tank/pillow that inflates and deflates with air, not the wire grid. GM changed the power lumbar system in either 09 or 10 I believe and the seat backs now only have a two position system to adjust the lumbar up and down. My 08 has the old system that has 4 adjustments, lumber up and down, as well as the pillow inflated and deflated. The good news is I have spoken with the warranty company and they said that everything should be covered based on the policy I have and I just need to take it to the dealer to have it fixed. I still have my doubts about them ACTUALLY covering it but I guess we'll see. I would pop open the seat back but I'm not sure how it's secured and don't want to start breaking anything.
Just in case anyone ever needs this for future reference...After taking the vehicle to the dealer they had to replace the entire lumbar support system in each seat...Grand Total...$50 Thanks to my extended warranty which ended up covering it! After riding in the truck for a couple of days now I think the seats have been messed up for quite sometime. It doesn't even sit the same anymore, much better. Very pleased in the service of my local dealer!
These are the kinds of story endings I like on here. :thumbs:
Thanks for replying back "Armyman". I'm glad your ext'd warranty "paid off" for you too.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
