Tranny Pan Drop???
My truck currently has 35,000mi and was thinking a tranny drop and filter swap should be in order as I tow my bass boat almost weekly. What exactly do I need to do besides drop the pan, put in a new filter, new gasket. Im sure ill need to add some oil that will be lost but what is my best choice and where do add it from? Any help would be greatly appreciated. Yes Ive tried the search option but seems they all turn into arguments about flushing and non flushing so that why I posted this.
Procedure link. It's a good general guide for dropping the pan. Your pan will not have a drain plug. Just in case you ask, if your pan looks like the pan in the write-up (has a step down) you have the deep pan and you will need the proper filter for it
You' re-fill using the trans dipstick tube at passenger side, read. See pic below
Use Dexron VI fluid 4-5 qts for pan drop
At some point, you may want to consider changing the fluid in your diffs.
also, you may have to loosen rear transmission mount a bit (put a extra small jack under it), then pan will comes out easy, don't force it, you might damage something (solenoid) etc.
my 5 cents worth advice :thumbs:
also the pan gasket is reusable so just get a filter from GM,,,,,dont bother digging out the seal ,it will be fine
add 3 quarts ,fire it up,level surface ,fill it to full cold mark, taking your time as using the dipstick tube has oil in it and checking the oil can give you a false reading ,,,so let the tube drain and check the oil ,you'll know what i mean when you do it
hope that helps also ^^^^^^^ what Joe said
Add a piggy back drain plug to the pan. Your filter won't need changing as often if you keep your fluid clean. I pull the plug once a year and swap out the 4 quarts that drains. You may also want to blow out the cooler lines while your getting dirty.
Merc-6? You mean Dexron 6?
DUH!! Yes, thanks for catching that. Must be my "golden" years sneaking up on me? :happysad:
(I just edited it)
I'd substitute one quart of the new DEX-6 for a bottle of SeaFoam brand trans conditioner.... :thumbs:
I wouldn't. No need for it
The seafoam tranny stuff is intended as a flushing cleaner/ water remover. It is not hydraulic fluid. Unless you cooked your fluid real bad or it is very old, I would skip it.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
